Hello...
I have Trailers in HD WMV, DivX and MOV in that i want converting to 2 types ....
1. to be watchable on stand-alone DVD players ... (VOB etc)
and
2. to be watchable on a DivX DVD Player .... (DivX/AVI/MPG etc)
also what is the highest resolution a normal DivX codec can display? (that would work on my DivX DVD Player)
Iam Quite good with PCs etc and know how to convert everything else...
THANKS
Results 1 to 30 of 33
would they still be in HD quality format tho? i have a film in WMV HD format that i want to play on either my xbox 360 or convert to HD DVD but is too big at moment for dual layer so is there a way to shrink the wmv file a little or ideally convert to HD DVD
Something like the latest Ulead DVD Moviefactory would be one of the cheapest HD DVD authoring options. The functionality is limited, but the output is HD.
You can convert - you don't want to converti have a HD DVD player and a HD WMV so i can't convertRead my blog here.
just opened it up and yeah there it is HD DVD STANDARD! doh! thanks for help
Arggh!! My post has been hijacked!!!Originally Posted by lordc007
HEHEHE
Thanks for the advice GUNSL1NGER I will give it a try and see how it goes
Try DVD Flick, or failing that, ConvertXtoDVD for DVD
WinFF might be worth a look for Xvid encodingRead my blog here.
WinAVI is low quality, unstable and unreliable and poorly supported. That you have to install a codec pack and risk crapping out the video playback of your system just to get it working should tell you to steer clear.
As for scaling down - you have to set an output resolution. If you want these to play on a Divx player you need to get the resolution down to 720 x 480 or less (NTSC) or 720 x 576 or less (PAL) unless you have a Divx Ultra player. You may have to consult whatever help comes with WinAVI on how to do this.Read my blog here.
thanks
Ive always used WinAVI for years and never had probs with it, i find it does a beter job the ConvertXtoDVD and is quicker... what is a Divx Ultra Player? -
You would be on of the few. And when it comes to encoding, speed is not virtue if it comes at the cost of quality. And with WinAVI, it does. However, if you are happy with it . . . .Originally Posted by snadge
Divx Ultra is the next level of Divx certification. Divx Ultra certified players can playback Divx files at HD resolution, higher bitrates, with menus and chapters etc.Read my blog here.
Divx Ultra does not include HD resolutions.
http://www.divx.com/certification/ -
theres no mention on that page that DivX Ultra does OR doesnt play HD...?
Does it? -
Divx Ultra does not include HD resolutions. They wouldn't forget to mention something that important.
Originally Posted by guns1inger
No longer HD, you are definitely right, period
But hey, do you know how to work with Paint Shop Pro or other similar soft ?
Movies is just only a bunch of images, you must up-resize, or down-resize just like you do in PSP...if you know it, or Corel, whatever...If you take a big image and down-resize...what method do you use ?
Well, you can take a big HD image and down-resize to standard PAL or NTSC using the right method
And if you use a good CQM...and just keep the original audio, then you will get definitely a extremely good DVD
It is all relative
Is DivX avi is better than flv, wmv, and mov?
By dread in forum Newbie / General discussionsReplies: 12Last Post: 20th Apr 2011, 12:38 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 04:54 -
Banding when converting MOV to WMV
By whoisquilty in forum MacReplies: 2Last Post: 22nd Jul 2008, 11:35 -
Converting WMV to divx/xvid
By mattr in forum MacReplies: 1Last Post: 3rd Jan 2008, 10:23
