I took all these files and all but two converted correctly:
VTS_01_1.VOB
VTS_02_1.VOB
VTS_03_1.VOB
VTS_04_1.VOB
VTS_05_1.VOB
VTS_05_2.VOB this is the problem file...it is the smallest in the bath at 133.4 MB
VTS_06_1.VOB
VTS_07_1.VOB
I get the following info:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Tue Jan 1 04:25:58 PST 2008
OB':
Duration: 00:03:11.9, start: 1491.393867, bitrate: 5831 kb/s
Stream #0.0[0xa0]: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Stream #0.1[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 7000 kb/s
Could not open '/Users/bdaul/Desktop/dce/VIDEO_TS/VTS_05_2.VOB.ff.mov'
IF I CHANGE THE OUTPUT FILE NAME I GET THIS ERROR:
Encoding started on Tue Jan 1 04:27:06 PST 2008
Input #0, mpeg, from '/Users/bdaul/Desktop/dce/VIDEO_TS/VTS_05_2.VOB':
Codec type mismatch for mapping #0.0 -> #0.0
HELP! Any suggestions? Thanks, --bill
1/ You should consider joining the files VTS_05_1.VOB and VTS_05_2.VOB, as they belong to the same Video Title Set (05). Then you can convert the combined file to one output file, which should be more convenient for the viewer.
2/ For "Codec type mismatch for mapping" errors, you should try setting the "Invert mapping" checkbox in the audio tab.
are there other tools to merge files together other than MTR 3.x? I guess I could try from the command line (unix) and hope I don't blow it.
thx
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 06:47 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 18:14 -
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 18:39 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 19:42 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50
