    Jan 2008
    Hi,
    I was trying to follow 45tripp's guide for good quality videos with Youtube, but I'm having a bit of trouble converting any mpg file to flv.
    The program I'm using to create the MPEG in the first place is ProShow Gold. I have no avi export option, and the only good quality one available is MPEG 2.
    So I've exported the file with that format, and am trying to encode it to FLV with mencoder, using the following command:
    mencoder vid.mpg -o test5.flv -sws 9 -of lavf -ovc lavc -lavcopts vcodec=flv:vbitrate=600:trell:v4mv:mv0:mbd=2:cbp:aic:cmp=3:subcmp=3 -oac mp3lame -lameopts abr:br=128:mode=3
    I immediately get a popup error saying: "mencoder.exe has encountered a problem and needs to close. We're sorry for the inconvenience."
    In case it is of any use, this is how far it gets in the command prompt:
    MEncoder dev-SVN-r25279-4.2.2 (C) 2000-2007 MPlayer Team
    CPU: AMD Athlon(tm) XP 3000+ (Family: 6, Model: 10, Stepping: 0)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
    Compiled with runtime CPU detection.
    117 audio & 238 video codecs
    success: format: 0  data: 0x0 - 0xb8f2000
    MPEG-PS file format detected.
    VIDEO:  MPEG2  448x336  (aspect 2)  29.970 fps  5000.0 kbps (625.0 kbyte/s)
    [V] filefmt:2  fourcc:0x10000002  size:448x336  fps:29.97  ftime:=0.0334
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    AUDIO: 44100 Hz, 2 ch, s16le, 224.0 kbit/15.87% (ratio: 28000->176400)
    Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
    ** MUXER_LAVF *************************************************************
    REMEMBER: MEncoder's libavformat muxing is presently broken and can generat
    INCORRECT files in the presence of B frames. Moreover, due to bugs MPlayer
    will play these INCORRECT files as if nothing were wrong!
    OK, exit
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 448 x 336 (preferred colorspace: Mpeg PES)
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    The selected video_out device is incompatible with this codec.
    Try appending the scale filter to your filter list,
    e.g. -vf spp,scale instead of -vf spp.
    VDecoder init failed :(
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
    Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
    It works fine for avi files, and I was also able to convert a m1v file to FLV, though of course without sound - it just seems to be stuck on the mpg files.
    Granted, I could convert the mpg to avi and then to flv, but converting to avi results in an incredible loss of quality.
    I'm using the latest version of mencoder.
    I tried this on my laptop, which runs Windows Server 2003, and it runs without a glitch, though the FLV files it creates are all fxxked, regardless of the source.
    Also, I'm not sure if this is related, but when I try to mux i.e. an avi or m1v file and any sort of audio file, mencoder crashes again. It's definitely the -audiofile switch, because it crashes whenever I insert that command, regardless of the rest of the command.
    Anyway if anyone can help, I'd be grateful, as I've just discovered mencoder yesterday and as they say, once you go black you never go back.
    Cheers
    EDIT
    This is what I get when doing step one, part two (ffmpeg):
    FFmpeg version SVN-r11143, Copyright (c) 2000-2007 Fabrice Bellard, et al.
      configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --
    enable-liba52 --enable-avisynth --enable-libamr-nb --enable-libamr-wb --enable-l
    ibfaac --enable-libfaad --enable-libgsm --enable-libmp3lame --enable-libnut --en
    able-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --cpu=i686 -
    -enable-memalign-hack --extra-ldflags=-static
      libavutil version: 49.5.0
      libavcodec version: 51.48.0
      libavformat version: 52.1.0
      built on Dec  3 2007 17:42:57, gcc: 4.2.2 (mingw32)
    Input #0, avs, from 'vid.avs':
      Duration: 00:04:50.6, start: 0.000000, bitrate: 0 kb/s
        Stream #0.0: Video: rawvideo, yuv420p, 448x336 [PAR 0:1 DAR 0:1], 43352 kb/s
    , 24.00 tb(r)
        Stream #0.1: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
    Output #0, flv, to 'ricky1.flv':
        Stream #0.0: Video: flv (hq), yuv420p, 448x336 [PAR 0:1 DAR 0:1], q=2-31, pa
    ss 1, 600 kb/s, 24.00 tb(c)
        Stream #0.1: Audio: libmp3lame, 44100 Hz, stereo, 128 kb/s
    Stream mapping:
      Stream #0.0 -> #0.0
      Stream #0.1 -> #0.1
    At that point it crashes just like mencoder.
    Jan 2008
    Well, I've managed to do the continuation of Step 1 from my laptop for god knows what reason, seeing that my desktop is my station with everything installed on it and my laptop has nothing. Ah well, I'm satisfied with that.
    Dec 2004
    Triptonia
    nothing wrong with the command.
    look to the builds.
    Try it with a mencoder build that's compiled for athlon
    http://esby.free.fr/CelticDruid/mirror/mplayer/
    I've heard of ffmpeg crashing on athlons when trying to encode to mp3...
    again try another build, don't use celtic druid's, try this:
    http://oss.netfarm.it/mplayer-win32.php
    gl
