Sirs, i have a question
Whenever I burn a MP4 movie about 400 MB, it automatically fills the 4.5 GB space in the DVD, how come it's doing that? When it just suppose to fil in 400+ space. Hmmmmm.. I use Nero 7 and I only have a generic burner. Halp!
Probably because Nero is re-encoding it to MPEG-2 format to be able to make a DVD from the file.
If you want to keep it in MPEG-4 format, burn it as a data file instead.
And welcome to our forums.
You are telling Nero to convert the file into a DVD Video format. Mpeg-2 compresses a lot less than Mpeg-4, so the file sizes grow. By default, Nero (and most conversion tools) will try to use the highest possible bitrate to minimise quality loss during conversion. My bet is that the running time of the video is round 90 minutes, which fills a DVD.
If you just want to burn the file to a DVD as data, use the Burning ROM part of Nero, Not Nerovision / Express.
Or start using Imgburn, as it doesn't do any conversion at all.Read my blog here.
Media Player Classic or VLC or KMPlayer.
You can use DVDIdentifier to check if you have a RW media....if it doesn't say RW on the dvd media. -
If you have Nero, CD-DVD Speed in "Tools==>Disc Info" will give you details about your media (DVD-R/RW, blank/finalized, manufacturer, etc.).
Burning a CD -- Minutes vs. File Size
By Opv in forum AudioReplies: 17Last Post: 5th Mar 2011, 22:55 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
Reduce file size vs. compression question. Am I doing this right?
By Ronny G in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 08:30 -
FLV File size question
By YoKnows in forum Video ConversionReplies: 3Last Post: 14th Jun 2007, 14:44 -
Captured File Size Question
By pbmc59 in forum Capturing and VCRReplies: 10Last Post: 6th May 2007, 20:41
