  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Whenever i download a certain file off a website i get an annoying error.
    'could not be saved, because the source file could not be read'
    I know its the anti virus blocking it.
    I am running NOD32.
    I really want this file. Even though it's dangerous.
    Can i somehow over ride this by disabling something then re enabling it again later? Thank you.
    Apr 2004
    Miskatonic U
    You would have to disable the anti-virus program, although I don't believe it is your problem. NOD32 won't see the virus until it is downloaded and can be scanned. The few times I have encountered this error message it has always been a problem at the server end, not mine.
    Read my blog here.
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    It's wierd.
    If i use the laptop in the other room it downloads. That has no anti virus on it.
    Any other suggestions mate?
    Thank you
    Apr 2004
    Miskatonic U
    Use the laptop and transfer with a USB key ?
    Read my blog here.
  5. Member SE14man's Avatar
    Jul 2005
    Queensland
    Thats a good idea. I then get the anti virus saying its picked up a virus on there. Then i go to services and its already stopped then i take ito ut of task manager and still get the problem. I cant seem to stop it detecting viruses. I just need to prevent it just this once!
    Thanks mate.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If it has a virus then it will pick it up at some point once it is on that machine. And why you would want to deliberately put an infected file on a machine is a mystery. Unless NOD has the ability to be told not to scan a particular file - some sort of exclusion list.
    Otherwise your choices are limited.
    Find a non-infected version of the file, or if NOD is wrongly identifying it as a virus, find a different anti-virus product.
    Read my blog here.
