I there, I used to convert xvid avi files into AVI x264 using VDubMod, but since reinstalling my XP SP2 system, I cannot see the codec in the list when going into the Save As... Options.
I choose .avi as the Container, but there is only XViD and a few others in the list of codecs, whereas before I has x264 and also RMVB (or something similar i think - how I made my .mkv's)
can anyone help me out please?
I have tried to install a x264 codec by Shark, but that did not work, and I have installed ffdshow again, and haali Splitter.
I also use autoGK for my DVD to XViD conversion, so don't want anything that will interfere with that process.
I use VDubMod, as it allows my to use the Logo Filter, which I need.
Thanks in advance.
[size=9]Zhare Your Info Article Publisher
R5DVD.com Support Team
VLCPlayer.info - My Favourite Media Player -
does it allow you to add your own logos?
also does it allow AVI to x264? or only DVDSources...?
would rather use VDubMod unless someone has tutorials how to add logos to your video with autoMKV and is possible to add a logo say from frame 1 to 1000 using png or bmp etc like \vdubmod... please reply only if you know what my needs are. thanks[size=9]Zhare Your Info Article Publisher
yea, VDubMod would be the go though... I have worked a few things out, by re-installing K-Lite Codec Pack, this gave me x264 encoder, but the result came out all fuzy and weird looking, so I am getting there... I dont use avisynth scripts as I am feeding AVI straight in, No VOBs etc, just changing AVI XViD -> AVI x264 and MKV
any help with this greatly appreciated... gotta be some VDubMod experts here, that know what I need from a fresh install to get this working?[size=9]Zhare Your Info Article Publisher
Converting x264 to .avi?
By Hank Kinsley in forum Video ConversionReplies: 2Last Post: 24th May 2010, 19:31 -
x264/mkv -> XviD/Avi?
By therock003 in forum Video ConversionReplies: 13Last Post: 9th Feb 2009, 16:53 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 01:07 -
Converting x264 to xvid for dvp642 standalone player
By ch4757 in forum Video ConversionReplies: 19Last Post: 23rd Jul 2007, 13:44 -
Having Problems converting h.264 mp4 to xvid using avisynth & vdubmod
By Rusty Shackleford in forum Video ConversionReplies: 3Last Post: 8th May 2007, 04:34
