I just bought a DVD recorder for my parents but it turns out it doesn't play their European PAL dvd's. So I'm looking for another one that can and also has a VCR. I did a search on here and only four came up, none of which looked good enough. I'd prefer to buy one in a store rather than online. Anyone have any ideas?
Hackable and format converting players alone are a bit of a challenge to find....I HIGHLY doubt you will find a hackable and format converting combo unit.
I'd suggest that your parents buy such a DVD recorder in Europe as anything you buy in the USA will ONLY record in NTSC. That's not what they are going to want. Philips makes a variety of DVD players that can easily be put into multi-region mode. I bought my father (he lives in the USA) an LG DVD recorder and it can be put into multi-region mode too, although he doesn't use that feature at all.
http://www.amazon.co.uk
will ship to the UK and Ireland and they sell electronics. If your parents live in another part of Europe, note that Amazon UK may refuse to ship electronics there. You might be best served to just wait until you go to visit them and buy a DVD recorder in a store AFTER you do the research to be sure it can be placed into multi-region mode.
PAL coded DVD in U.S. player?
By Goodluck Jonathan in forum Newbie / General discussionsReplies: 50Last Post: 16th Apr 2012, 23:27 -
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 18:56 -
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 03:54 -
Best region free PAL DVD player for $50 - $70
By jamest in forum DVD & Blu-ray PlayersReplies: 9Last Post: 26th Jun 2009, 04:53 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 07:40
