    Believe it or not but i am trying to backup this old movie (from 2003) with Jamie Kennedy called Malibu's Most Wanted and i keep getting read error about 30 seconds into the rip. I am using dvdfab hd decrypter version 4012 which is only a few weeks old and it is really puzzling. The mesage i get is "DVDfab HD Decryter encounters a reading error (may be caused by protection) which can be removed by using Pathplayer . . . blah blah. Would you like to restart dvdfab . . and enable pathplayer?" So i do and i still get the error. I was wondering if anyone has had problem with this older movie and can tell me what they used to back it up.
    Fun in the sun, Oh no my friend, Fun on the sun!
    Apr 2004
    Miskatonic U
    Try using DVD Decrypter and see what it says. My guess would be scratches or finger prints
    Read my blog here.
    man do i feel like a horse's ass Brand new out of the plastic and into dvd burner and wont rip, i spray with my wife's lense cleaner for her eye glasses and wipe off with a soft cloth and wa luh it works You have got to be kidding me, i've ripped dvd's with scratches in them no problem and this brand new one just needed wiped off. Thanks gunslinger. Buy the way what does one recommend to use to clean dvd's?
    Apr 2004
    Miskatonic U
    Warm water with a mild detergent and a soft cloth usually does the trick, although I find Windez can also help and is a quicker solution
    Read my blog here.
