    Apr 2007
    Hi everyone,
    I'm having a problem with my DVD authoring software (Sonic MyDVD Deluxe)
    The program was working great, until suddenly the Fit to DVD feature messed up and now I can't burn quality movies at all.
    The Fit to DVD feature is to adjust the compression of the movie if say you want to add more time to the DVD, the more time, the more compressed. It has the quality levels of HQ, SP, LP, and EP.
    As you all know EP is the lowest quality.
    The thing is that I add a 5 minute clip to the project, and the clock hand moves all the way down to EP... thats where I'm having a problem. Usually it hits EP when theres ia like 3 hours of video in the project, but 5 minutes?????
    I ignored it and just birned the movie, but like expected, it looks bad.
    I tried re-installing the prgram, and deleting the registry folders too, but no luck.
    Is there something I'm missing?
    (the workaround solution i had for some time was that I opened previous saved projects from when the program worked fine, I just changed the video files, and everything still was fine; but I forgot about that workround and started deleting the video files that were used by each project, and now the project won't open, this isn't really relevant but I thought it might help)
    Aug 2007
    Yes, I think there is. In my opinion, you are missing reliable and effective software.
    Depending on your needs, I might recommend you consider using other software programs(s) to create your projects / movies / discs.
