I'd prefer the PICVideo before the Huffyuv-codec, if it wasn't for the "interlace-type" of "lines" around some objects in my capture. Capture in VD at 704*576 downsize to 352*288. Tried some deinterlace but it doesn't seem to work. And if i'm using Huffyuv-codec this issue never appears. I'm capturing from vhs-video and as it is in pal I don't think it's interlaced.
Hmmmm....
Seems like the problem is within the choise of RGB-colour. If i choose YUY2 I don't get the "lines". If i'd know how, I would have showed you a screenshot. -
Did some more testing and it seems like i get this error if i use rgb24-bit but not in rgb16-bit. Is this a hardware or software problem?
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 17:53 -
Can't get rid of interlace lines
By MacFast in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 22:41 -
Convert 4:3 PICVideo mjpeg to 16:9 DV w/o losing clarity
By brassplyer in forum EditingReplies: 12Last Post: 5th Jan 2011, 02:13 -
Seeing interlace lines after exporting from After Effects
By theguy1991 in forum EditingReplies: 14Last Post: 15th Jun 2010, 15:39 -
Kind of scrolling lines when playing avi's
By belveder in forum Software PlayingReplies: 4Last Post: 1st Mar 2009, 15:05
