I've been using vob2mpg v2.5 for a few weeks now without any issue. I've ripped 10+ DVDs with DVD Decrypter and converted them to mpg successfully with vob2mpg. I am running on XP Pro with SP2; dual core, lots of DDR and lots of HDD space.
Today vob2mpg won't even start; I get an XP error dialog with "vob2mpg has encountered a problem and needs to close". Looking at the logs tell me nothing because it doesn't even get far enough to write the log. The last entry is a successful conversion on 12/27. I can't tell you the exact vob2mpg version because now it won't start. It was downloaded from the official site at the beginning of December though...
I allowed Windows Update to install recently, incidentally also on the 27th??? Anyone know if the latest December updates somehow break compatibility for vob2mpeg?
Also, I've installed many 3rd party proggies such as codecs, encoders, etc, etc. Assuming vob2mpg is totally standalone and none of these corrupted the install?
i've re-installed and repaired and un-installed many times now and the result is the same. I've manually deleted all the registry entries and installed from scratch and nothing changes.
Thanks in advance for any and all help!!!
Ragu
Shouldn't be the codecs, but it might be the update. Have you tried a system restore?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Good tip regarding the restore. I will try that.
Hadn't thought about checking here earlier, but this makes me think it is related to the .NET framework. Here's the report from the Event Viewer -> Application log.
Event Type: Error
Event Source: .NET Runtime 2.0 Error Reporting
Event Category: None
Event ID: 1000
Date: 12/31/2007
Time: 10:41:53 AM
User: N/A
Computer: HQ-PL-SALES18
Description:
Faulting application vob2mpg.exe, version 0.0.0.0, stamp 00000022, faulting module kernel32.dll, version 5.1.2600.3119, stamp 46239bd5, debug? 0, fault address 0x00012a5b.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
0008: 69 00 63 00 61 00 74 00 i.c.a.t.
0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
0020: 75 00 72 00 65 00 20 00 u.r.e. .
0028: 20 00 76 00 6f 00 62 00 .v.o.b.
0030: 32 00 6d 00 70 00 67 00 2.m.p.g.
0038: 2e 00 65 00 78 00 65 00 ..e.x.e.
0040: 20 00 30 00 2e 00 30 00 .0...0.
0048: 2e 00 30 00 2e 00 30 00 ..0...0.
0050: 20 00 30 00 30 00 30 00 .0.0.0.
0058: 30 00 30 00 30 00 32 00 0.0.0.2.
0060: 32 00 20 00 69 00 6e 00 2. .i.n.
0068: 20 00 6b 00 65 00 72 00 .k.e.r.
0070: 6e 00 65 00 6c 00 33 00 n.e.l.3.
0078: 32 00 2e 00 64 00 6c 00 2...d.l.
0080: 6c 00 20 00 35 00 2e 00 l. .5...
0088: 31 00 2e 00 32 00 36 00 1...2.6.
0090: 30 00 30 00 2e 00 33 00 0.0...3.
0098: 31 00 31 00 39 00 20 00 1.1.9. .
00a0: 34 00 36 00 32 00 33 00 4.6.2.3.
00a8: 39 00 62 00 64 00 35 00 9.b.d.5.
00b0: 20 00 66 00 44 00 65 00 .f.D.e.
00b8: 62 00 75 00 67 00 20 00 b.u.g. .
00c0: 30 00 20 00 61 00 74 00 0. .a.t.
00c8: 20 00 6f 00 66 00 66 00 .o.f.f.
00d0: 73 00 65 00 74 00 20 00 s.e.t. .
00d8: 30 00 30 00 30 00 31 00 0.0.0.1.
00e0: 32 00 61 00 35 00 62 00 2.a.5.b.
00e8: 0d 00 0a 00 .... -
I have no idea from that error what exactly is causing it. My suspicion is the same as yours - that it resulted from the update. If running the restore point from just prior to the update works, then we'll have to track down the cause from the update.
Dwight
- Herm Albright
Restore isn't working at all; no matter how old or how recent a point I choose after it churns for a few minutes and reboots I get the message that the restore point cannot be used.
I manually uninstalled all 12 updates that were applied 12/27 but that isn't working either??? I'll post exactly which ones were added later
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 14:53 -
No POST during startup
By mysts in forum ComputerReplies: 5Last Post: 25th Oct 2011, 01:47 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Vdubmod Crashes On Startup Kernel32 Error
By Konfusion in forum Video ConversionReplies: 10Last Post: 31st May 2009, 15:19 -
CloneDVD 2 crashes at startup
By pacopaco in forum DVD RippingReplies: 3Last Post: 24th Jan 2008, 14:28
