Hi folks...trying to convert an mp4 to a .mov....haven't had a problem with this before until today. I've tried all sorts of adjustments. It keeps stopping once the .mov files reach 4 KB.
Here are the logs I've gotten with each time I've tried:
1st try:
Encoding started on Mon Dec 31 10:57:55 EST 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Seems that stream 0 comes from film source: 48000.00 (48000/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/pewterreport/Documents/STORAGELABS_TINYUDF.mp4':
Duration: 00:09:35.9, start: 0.000000, bitrate: 31944 kb/s
Stream #0.0(eng), 29.97 fps(r): Video: h264, yuv420p, 718x480
Stream #0.1(und): Audio: aac, 48000 Hz, stereo
Output #0, mov, to '/Users/pewterreport/Documents/STORAGELABS_TINYUDF2.mp4.ff.mov.avi.mov':
Stream #0.0, 29.97 fps(c): Video: mpeg4, yuv420p, 800x608, q=2-9, 1809 kb/s
Stream #0.1: Audio: aac, 48000 Hz, stereo, 96 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
2nd try:
Mon Dec 31 10:58:47 EST 2007
Stream #0.0, 29.97 fps(c): Video: mpeg4, yuv420p, 800x608, q=2-9, 3274 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
3rd try:
Mon Dec 31 11:01:18 EST 2007
Stream #0.0, 29.97 fps(c): Video: mpeg4, yuv420p, 800x592, q=2-9, 3188 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
4th try
Mon Dec 31 11:03:21 EST 2007
Output #0, mov, to '/Users/pewterreport/Documents/STORAGELABS_TINYUDF.mp4.ff.mov':
Stream #0.0, 29.97 fps(c): Video: mpeg4, yuv420p, 1584x880, q=2-9, 9586 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Sorry that was so lengthy, folks. Any and all help would be greatly appreciated as I'm under deadline and I've got to convert this file and have it up on our company's site asap. Thanks!!
JL
	I'm not seeing any error message in any of the tries.
 Did you get the 'ping' (finished) or 'donk' (error) sound that usually comes when the encoder finishes?
 Holy bitrate, Batman! That 31944 is 26 times more than an efficient codec like H.264 needs! Who made you source file? (It is possible that the number is off, as it could be from the header instead of calculated.)Originally Posted by JennaLaine
 1584x880 seems a bit large for web video?!? Video sites like YouTube go with 320x240.Originally Posted by JennaLaine
 You could try checking the "Decode with QT" checkbox in the Options tab, to see if that makes a difference.
 And at the risk of stating the obvious, did you check for enough free disk space?
  .mov to .mp4 errorBy ShadeChar in forum ffmpegX general discussionReplies: 7Last Post: 24th Apr 2012, 16:38
  M2TS to MOV/MP4By thunderclap82 in forum Video ConversionReplies: 2Last Post: 25th Mar 2010, 10:02
  MOV to MP4By nextoss in forum Video ConversionReplies: 3Last Post: 11th Jan 2010, 16:50
  HD .mp4 and .mov to xvidBy capo327 in forum Video ConversionReplies: 2Last Post: 17th Jan 2009, 18:44
  WMP and mov,mp4,etcBy rock.freak667 in forum Software PlayingReplies: 3Last Post: 20th Apr 2008, 05:04
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
