Hi, y'all! Happy New Year's!
I converted an avi file to MPEG-2 so it would work better with my standalone DVD player (Samsung DVD-P247A). I converted it with Magic Video Converter, then proceeded to burn it with Ashampoo Burning Studio 7. The file, when it was an avi and after i converted it, worked perfectly on the computer, but when i put it into my dvd player the audio was gone. I don't know whether I've done something wrong, I need a codec, or I need to convert it to a different file format. Any help would be appreciated.
Welcome to VideoHelp!
You're probably lacking some audio codec yes.
Use GSpot on the AVI to see what audio codec is in the AVI.
For easy AVI to DVD conversion, use convertx2dvd or (free) FAVC.
Never heard of "Magic Video Converter", but together with "Eazy" and "Express", "Magic" in the name of an application makes me wary.
If you like reading & learning, look under Convert left, AVI to DVD. 50 guides last time I looked.
Better yet: Get a DVD player that also plays AVI. Costs about the same as most commercial AVI to DVD offerings.
/Mats -
To add to Mats' excellent post, do note that if your AVI files have AAC audio that almost no DVD players that support Divx/Xvid files can play this kind of audio.
Thank you oh-so-much.
With the aid of GSpot and convertx2dvd, the audio was restored.
And I wouldn't have stumbled across them without your help.
Blessss youuu.
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 15:52
