Hello,
I am trying to convert my old vhs-c tapes to a digital format.
I am having trouble rewinding and fast forwarding these tapes. They will play back, but I am never sure if I have really reached the end or started at the beginning. I will be rewinding the tape and it will stop as if it is at the beginning. But if I select rewind again it will rewind some more. The same with fast forwarding.
I have tried playing these tapes in two different VCR's. The second one is a brand new Zenith DVD/VCR combo, model # XBV713.
The vhs-c adapter I have is the one that came with the camera. (I should mention the camera is broken). Would it be wise to try a new vhs-c adapter? Could that be the problem? Or is there something wrong with the tapes?
Thanks, Bill
	Are you using a motorized adapter? Perhaps fresh batteries help? Does the tape appear to have reached the end/beginning when you look inside the clear window on the vhs-c cassette?
 You can help avoid many potentially problematic issues by cleaning or having your VCR cleaned prior to undertaking your project.
	Many VCR's stop when they get to zero on the footage meter, regardless of where the end of the tape actually is. I would just get used to checking, or use a seperate VCR rewinder.. Rob
	I installed a new battery in the adapter.
 Rob I think your info about the vcr stopping when the counter reaches zero may have been part of the problem.
 I will know for sure in a few days when I have more time.
 Thanks to both of you. I am new to video editing and this forum. The forum is a great resource.
 Bill
	My adapter never even worked right when it was new. I played back all of my tapes in the camcorder when it was time to transfer to digital.
 Do you still have the camcorder?
	No, my VHS-C camcorder failed a few years back. The tapes have been sitting in a drawer for years and I finally decided I need to convert them.
 It would be great if the camera still worked. If it did I wouldn't have gone out yesterday and purchased a DVD/VCR combo unit.
 Thanks for the reply, Bill
  Best UK PAL VHS / D-VHS machines for digitising old VHS tapesBy pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21
  DVHS VCR performance with EP speed tapes and VHS-C tapes?By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36
  For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27
  Trouble with playback of 8 mm of broken camcorder’s tapesBy 1234567 in forum Off topicReplies: 6Last Post: 7th Dec 2008, 14:19
  New VCRs Have Trouble with Older TapesBy homeboy in forum RestorationReplies: 15Last Post: 30th Mar 2008, 20:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
