    Nov 2007
    Has anyone used this yet?
    I want to buy it, however I downloaded the trial
    and it did not work. It said that it expired already
    and I just downloaded it.
    Is this up to date with FCPS2 and the new Mac
    software? Just wondering.
    - James
    Dec 2003
    Eugene, Oregon
    I don't have that application because I have Toast 8, Cinematize and MPEG Streamclip that all can export video from a VIDEO_TS folder to DV or full quality QuickTime movie.
    Jun 2006
    Does Toast 8 convert Video_TS folder to DV without Streamclips?
    Dec 2003
    Eugene, Oregon
    Yes, but it's a 2-step process. First you use the Toast Media Browser to access the titles within the VIDEO_TS and drag them to the main Toast window to extract them as MPEG 2 files. Then you select those extracted files and export to DV.
    Nov 2007
    OK well none of this really helps me since I'm buying DVDxDV
    If anyone has used it please respond.
    Dec 2003
    Eugene, Oregon
    What have you heard from the developer as to why the trial version didn't work? There are user comments about different applications at versiontracker.com and macupdate.com. This application has been available for a few years so there should be user comments.
