I'm a newbie to the HD world. I got my first HD box from Time Warner. I have it hooked up via HDMI to my new sony 40w3000 lcd. Is there any work around to get rid of the HDCP thingy? I don't wanna use component cables. I've read countless threads re: SA 8300 HD problems but no real answer on how to get rid of that HDCP message. A few minutes after I get that msg. I'm able to get any cable station. But as soon as I turn off the lcd tv then turn it back on that msg appears again. I know HDCP stands for high bandwidth content protection but hell what I'm recording on vcr isn't hd. I'm not able to record off the hd box to my vcr as well if the lcd tv is shut off. I'm assuming because of the HDMI on the tv is turned off there would be no signal going through. I've racked my brains trying to figure this out. My cousin has the same HD box but he doesn't get that HDCP message saying to use component cables so I'm assuming the hd box I have is defective. I've also powered off the hd box and let it reboot as well but I still get the HDCP thingy. I've asked for a new hd box which will be picked up tomorrow.
I hooked up the hd box via component cables and it's freaking fugly. HDMI looks much better than that.
I would appreciate any advice/comments with this matter. Thanks in advance!
	I've seen a few posts recently concerning similar issues between various TV's and HD receivers. For the most part, it seems to be related to specific HD boxes. I have a Motorola box through Charter, and the HDMI or component outputs are both HD with similar quality. This will vary slightly from TV to TV, but the result should be close.
 Some boxes allow you to set the output type and/or resolution.Google is your Friend
	I've got the 8500HD box hooked up to a Samsung 4665F at my current location and don't see this happening when the HDTV is shut off. The HDCP connection is established when the TV is first turned on. Most HDTV sets keep the HDMI port powered even when the TV is turned "off" to keep the connection active. HDCP monitors the port for connection periodically. Are you unplugging the TV?
 This may be a firmware or box hardware variation. Does Time Warner offer an explanation? Demand a 2nd or 3rd tier support expert until you get an answer. Sony support may also have an explanation re: HDCP.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	 Thanks for the replies Krispy Kritter and edDV! Thanks for the replies Krispy Kritter and edDV!
 To edDv: I'm not unplugging my LCD TV.
 To Krispy Kritter: Unfortunately my local cable company, Oceanic Time Warner Cable doesn't use the Motorola HD boxes. They only use the SCIENTIFIC ATLANTA 8300 HDC boxes.
 I got the replacement 8300 hd box which supposedly is brand new since Oceanic Time Warner got 6000 HD boxes in time for the Sugar Bowl game on New Year's Day. The University of Hawaii is in it's first BCS bowl game which the entire island chain is excited to watch the game on TV in HD. The University of Hawaii is in it's first BCS bowl game which the entire island chain is excited to watch the game on TV in HD.
 EDIT: Second HD box is fine so far at least when powering off my Sony LCD TV the HDMI signal is not lost. DVR is fine as well. Okay now so far everything is working w/HDMI and vhs recorder. Yes, my folks like having me tape their Korean and Japanese dramas for them on vhs tapes.
  Any way to record from my Sky HD box? through AV or HDMI?By gretaro in forum DVB / IPTVReplies: 2Last Post: 9th Apr 2011, 15:08
  Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable boxBy aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21
  How can I use DVI analog inputs and HDMI from Cable box?By hamiltonpl in forum DVB / IPTVReplies: 3Last Post: 15th Jan 2009, 21:28
  Scientific Atlanta HD Cable Box / HDMI Audio ProblemBy culttvguy in forum DVB / IPTVReplies: 5Last Post: 14th Sep 2008, 16:48
  Code Free does not work daewoo dvg 8300 seBy ramona in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 11:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
