The installation of the Geniatech One Touch Grabber software and drivers went fine. I have been trying to capture video from a VCR, using the RCA out connections, but no video will display in the Grabber software. Any suggestions appreciated.
I finally got it to work. For some reason it will not work in the USB inputs on the front of my computer but it will work with the ones on the rear of the computer. Any idea why this would be? It's a bit of a hassle to get to the rear of the computer.
Front USB is often 1.1, while rear are 2.0. Stupid, I know. Get a 2.0 USB hub (or a USB extender cable) to make your rear connectors more accessible.
/Mats -
I would check to make sure the connectors for your front usbs are not loose, both on the usb itself and the mobo.
What We Do In Life, Echoes In Eternity.... -
Lots of complaints posted about front USB connections.
Personally, I quit the battle and use the back ones.
Will try again with next motherboard and case that I buy. -
This is probably what's going on. I have no trouble using flash drives in the front USB ports so it's not a connection problem. The USB extender cable does sound like the solution... thanks.Originally Posted by mats.hogberg
2.0 USB Video Grabber
By newman2 in forum Capturing and VCRReplies: 1Last Post: 4th Jan 2012, 02:15 -
Touch screen monitors or all in one touch screen pc?
By Rudyard in forum ComputerReplies: 4Last Post: 1st Dec 2010, 09:02 -
One Touch Grabber Problem
By elwood55 in forum Capturing and VCRReplies: 0Last Post: 4th Sep 2010, 17:26 -
Image Grabber 2.... DirectDraw?
By nuhkka in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 17:15 -
YouTube grabber not grabbing
By Tbag in forum ComputerReplies: 6Last Post: 4th Dec 2007, 06:22
