Hey Guys,
First off I just wanted to say that I have looked through the guides and didn't find my solution. I am new to Ripping and burning DVD's so this might be an easy fix.
I'm trying to Rip and Burn an entire DVD9 DVD Movie. I started off by installing AnyDVD which is running the entire time. I placed the Newly released movie in the DVD Drive and AnyDVD does its thing and says I can access the DVD now. I open up CloneDVD, Latest Version of Both AnyDVD and CloneDVD by the way. I rip the DVD Files to my Harddrive. Not as an ISO but as a Video_ts folder. That all goes fine. When I procceed to burn the Files onto a Memorex DVD-R DL, It says it was successfully burned, but when trying to put it into an Xbox360 it will say Unreadable Disc, and when I try to put it back into the computer it won't read the disc at all.
Am I just missing something here. I would appreciate your help. If there is a guide I missed out there please point me to it.
|-Goku-|
Results 1 to 10 of 10
Yes. Memorex DL discs are crap. In fact, pretty much anything except Verbatim +R DL discs are not worth buying. Verbatim are the only brand that are producing relatively consistent results at this time.Am I just missing something here.
Imgburn is the recommended software for burning DL discs.Read my blog here.
Still no luck, Burning Coasters here, have already wasted 6 Dual Layer Disc. Is there anyone that can help me?
MEMOREX DL media is purely crap. You want successful burns then use as suggested VERBATIM DL media. This has been mentioned what 10 times a day in different forums. So what if your 360 games were burned with MEMOREX dvd media. That doesn't mean a thing. Do some reading in the media forum or do a search in google.
IMGBURN website:
http://www.imgburn.com/ -
You don't need to build an ISO with Imgburn, it can burn directly. Regardless, the process is the same. Start in Build mode and select your Video_TS folder. If you set you output to Disc then you will burn directly. If you set it to ISO you will create an ISO.
No, Imgburn does not decrypt. The author has already been there and been spanked by the man for his troubles.Read my blog here.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Burning 720p Avi. Movie to Dual Layer DVD
By Falco21 in forum Video ConversionReplies: 2Last Post: 28th Feb 2011, 15:06 -
Question on Dual Layer burning....
By ranchhand in forum DVD RippingReplies: 12Last Post: 4th Dec 2010, 17:26 -
Burning dual layer question
By ny888 in forum DVD & Blu-ray WritersReplies: 2Last Post: 4th Dec 2008, 19:01 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
