Ok .. I have an Axion .. I got it for Christmas 2 years ago, and I have 2 questions.
1. What is the name of the cord that I can get to hook it up to a regular TV, and where would I find one?
2. Does anyone know why my DVD player won`t charge? Like, it works when it`s plugged into an electrical outlet, but like, if it comes unplugged, it immediately turns off.
Thanks for anyone who can help me=)
Just guessing, but I think you are looking for a A/V cable or TV adapter. Try a Google search for ' Axion TV adapter '. Adding in the model number would help. It may just be a stereo 1/8" phone plug to two RCA plugs. Depends on what output jacks your unit has. If that's what it is, a common stereo audio 1/8" to RCA plug adapter would work. You can get that at many big box stores.
If your player won't charge, most likely the battery is worn out. Replace it.
You might also do a search for some Axion forums. If they exist, they may give better info.
And welcome to our forums.
thanks=)
how do i know the model number?
And where would I get a new battery? -
redwudz - you sure keep busy around here
the sticker on the back?how do i know the model number?
what's the model number?And where would I get a new battery? -
Ok .. there are 2 stickers on the back .. 1 says the serial number, and the other one says 06A05
Hi, here are a few ideas to get us going in the right direction
Batteries:
http://www.shopaxion.com/product.php?category=[BATTERYPACKS]
Tech support email: techsupport@axiontv.com
Customer service email: customerservice@axiontv.com
Friendly customer support specialist is available at:
Phone: 909.869.6600 ext: 11
Fax: 909.869.5545
M-F, 8:30AM to 5:00PM, PST.
Portable DVD Players With USB Support
By JohnDodds in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Jan 2010, 17:17 -
PORTABLE Dvd Players vs. ones with DivX
By maris in forum DVD & Blu-ray PlayersReplies: 12Last Post: 4th Jan 2010, 12:06 -
dvd players and portable hdd?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2009, 17:44 -
Buying advice for portable DVD players?
By lordsmurf in forum Portable VideoReplies: 0Last Post: 12th Sep 2007, 10:58 -
multi-region portable dvd players
By mech1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 07:36
