    Nov 2002
    I have been using the GSA-4160B for about 2 years now mostly to read (to my computer) DVD-RAM disks recorded on a Panasonic stand alone DVD Recorder with no problems. Now for some reason it will not read DVD-RAM disk and I get "There is no disk in the drive". I have the latest Firmware installed. Anybody out there have any suggestions??
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It is likely dirty and just needs a cleaning, or it is failing/failed and needs to be replaced. Especially if it is still reading other discs without any issues.
    Google is your Friend
    Nov 2002
    If the unit is dirty how does one go about cleaning it??
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You can try blowing it out with air or open the unit and clean the lense with a Q-tip and some alcohol.
