Greetings,
Since those MKV files can be pretty large, I've seen as large as 14GB, what is everyone doing about saving these files, especially since it can overwhelm a hard drive in short order.
Besides investing in a Blu-ray or HD recorder, can they be broken up to fit on Dual Layer DVDs or even single layer DVDs for the smaller 6GB stuff?
thx
You may be able to split them with MKVExtractGUI. For other MKV programs, try a search in our 'Tools' section for ' mkv '.
It pretty much boils down to how you are using them. If they are that big, they are likely HD rip's. The question becomes how are you using them? and whether or not you need to keep files of that size/quality. Depending on how you are using them, you could convert to another format or reencode to reduce the size.
Of course, you could always just buy the content, then it would already be on a disc.Google is your Friend
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 19:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
