I want to convert a 4 min 285mgb music video to upload to Photobucket. I'm looking for suggestions as to the best way to do this.
	divx or xvid. Use any of the conversion tools found in the tools section.
 Just be aware that whatever your desired file size is will have lower quality with the compression. Be warned.... But that said you can get it to look good if you work at it but you shouldn't expect the same quality as the original file.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Also, photobucket is doing what most other storage sites are doing and converting to low quality FLV files.
 If you're concerned about quality, a site like stage6.divx.com would be a better choice.
  avisynth -> imageSource + sound (4min) = 40 sec video in vDubBy adom in forum Video ConversionReplies: 4Last Post: 22nd Feb 2011, 18:53
  Video converting suggestionsBy kreshnik in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2010, 17:19
  Converting AVI to Video-TSBy rooney1111 in forum MacReplies: 2Last Post: 5th Mar 2009, 13:06
  question about converting rmvb video file to avi videoBy jimdagys in forum Video ConversionReplies: 5Last Post: 17th Nov 2007, 00:51
  Converting an AVI video with AC3 audio to an AVI video with MP3 audioBy rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
