My boyfriend bought EasyCap USB 2.0, which supposedly supports 60HZ, only we can't get it to work like we weant it to. Using Virtualdub, we'll manage to get a signal, but it'll be in Black and White.
What are we doing wrong and how do we fix this?
The specs say that it supports either NTSC or PAL.
You may want to try capturing with VirtualVCR but that app wouldn't even open on my system.Support NTSC, PAL Video format.
Supports high quality video resolution: NTSC 720 x 480 @ 30fps, PAL 720 x 576 @ 25fps
I have a feeling you have been terribly lied to.
Easycap usb large capture files
By visionman in forum Capturing and VCRReplies: 5Last Post: 4th May 2010, 18:23 -
Does EasyCap USB 2.0 D60 Have A Home?
By mediachimp in forum Capturing and VCRReplies: 3Last Post: 4th Apr 2010, 23:23 -
Easycap Capture, USB 2.0
By Kimmytattoo in forum Capturing and VCRReplies: 2Last Post: 16th Jan 2010, 15:13 -
Not getting audio using Easycap usb 2.0
By heman31 in forum Capturing and VCRReplies: 0Last Post: 1st Jun 2009, 18:27 -
EasyCAP 2.0 USB = No Sound on Capture????
By williamgibbs in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2009, 09:15
