Hi, which is the best TV capture card on the market at the moment?
All the ones I can find are a few years old, there seems to be no new ones around!?
thanks alot
				Results 1 to 9 of 9
	What format do you want to capture to? And do you want HDTV capture? HDTV may be one reason there aren't too many new ones out there as the SD ones will be mostly obsolete shortly, at least in this country.
 I still like the Hauppauge MPEG-2 cards at present.
	Ditto.Originally Posted by redwudz
 I'm a new owner of an old PVR-350 and it's REALLY nice.
	3 + years on my Hauppauge and I still haven't found reason to change. Seems like good stuff to me.
	thanks for your replies.
 I have a HD camcorder, are there any which have HDMI inputs aswell as composite inputs?
 I dont mind about the format it is recorded in, I just wanted to be able to put my HD videos onto my PC if its possible?
 thanks alot
	HD as in HD DV? You don't need a capture card for this. Capture cards are for analog video. You transfer the digital video from a DV cam using Firewire.
 /Mats
	well for the price twinhan 1020a (30usd) is one of the best fta devices... hauppauge 150, 350, 500 lines are good too for ota reception (also for dumb dvcr capture)...i have used the 350 & the 150 versions
	I'm a very satisfied owner of a Hauppauge PVR-350 card. The 150 card is hit or miss. It works great for some people. For others, it doesn't work at all. Nobody seems to know why. It's just some random thing about your PC hardware. I generally don't recommend the PVR-150 unless people know going in that they may have big problems with it and are willing to take that chance. Unless you simply must have AVI recording (the 150 supports this and the 250/350 do not because of different chipsets on the card), I generally recommend the 250 or 350 Hauppauge cards.
	I have Kworld PVR-TV 7131. This works fine.
 It has Composite & S-Video inputs along with analog NTSC TV tuner.
 It has Philips chip on board for realtime mpeg 1/2/4 conversion.
 I got it for $5 after mail in rebate 2 years back.
  Capture card for Laserdisc and VHS - Good card/qualityBy darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27
  Connecting TV Tuner Card / Sound card for best audio capture??By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13
  Capture card or Video card w/ capture toolBy joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45
  Quality of a DVB/Tuner card ; but simplicity of a Capture card.By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
  Using Capture/Recoding PCI card - GV-650 Video Capture CardBy Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
