I installed avi_io and virtualdub only to find out they are the same program only with virtualdub has manymore features.
Anyhow... i set an option in avi_io in the "video capture" section to "24 RGB" from "16 RGB" and my system froze.
I then reset my system, and I go back into avi_io .... well it reboots my computer.
I try to go into virtualdub and it freezes when I go to the "capture avi" setting.
How can I fix this? has anyone else had this problem.
I was using AVI_IO version C 03.22 and VirtualDub 1.4.8
Windows 98
Results 1 to 1 of 1
Video Causing Computer to Freeze
By Ownaholic in forum Software PlayingReplies: 4Last Post: 26th Apr 2012, 12:10 -
Avisynth reboot
By romanticwarrior in forum Video ConversionReplies: 1Last Post: 6th Oct 2010, 01:11 -
Removing VirtualDub from Computer
By Sidus1 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 17:04 -
XP - Reboot cycle
By Ai Haibara in forum ComputerReplies: 7Last Post: 3rd Sep 2008, 15:19 -
my computer freeze all the time
By ieh4f in forum ComputerReplies: 13Last Post: 24th May 2007, 11:50
