Hi,
I have VCD1.ISO and VCD2.ISO. Each contain similar folders and files. The file AVSEQ01.dat is present in both the iso's (different sizes though).
Do I need to merge them, and if so how? And which program is best to play the videos?
Thanks for your help!
Thank you, nice to be here
At this point I just want to play them as I'm not even sure what they're about. Trying to play avseq01.dat using VLC gives me garbled sound and a black screen which makes for interesting but not-really-satisfying viewing
And yes, if it's worth keeping than I guess I would want to burn it to DVD. -
they are most likely disc images of vcd cd discs. use a burning prgram that handles iso images - like imgburn to burn onto cd. they can be played in some standalones or most dvd software on your comp will play them.
Thanks for the advice, much appreciated!
Will get into it straight away.
avseq01.dat file in mpegav directory
By ComputerScience in forum Newbie / General discussionsReplies: 8Last Post: 17th Jun 2011, 15:34 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 11:13 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
How to edit AVSEQ01 on windows
By emzhyd in forum EditingReplies: 3Last Post: 24th Oct 2007, 21:47
