Do dropped frames mean the file is short time for those missing frames? I have two hour long camera angles and they don't stay in sync (if you sync the two at the beginning it's off at the end and visa versa). Thank you!
Results 1 to 11 of 11
I presume, from the forum you posted in, that you're transferring from DV or HDV cams to PC via firewire?
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You are assuming that both cameras are perfectly calibrated to each other and therefore recording at exactly the same speed. This is highly unlikely, and there is a good chance that the videos will drift over time.
However if you are dropping frames then you will definitely get sync issues.Read my blog here.
I'm using Premiere Pro. It's interesting that the timing of two DV cameras can differ. Thanks again!
I agree with guns1inger - WinDV is a better choice.Originally Posted by kippard
If you think about it, cameras - even the exact same models - are mechanically based and so can be slightly different. Assume that there's a 1% difference in the running speed due to slight mechanical gearing differences and the like. Over 1 hour (60 mins x 60 secs = 3,600 seconds) that's an error of 36 seconds. Even if it was 0.1% it'd still be 3.6 seconds.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Kippard,
Can you tell us more about your gear.
When dropping frame occurs, usually, it is your hard drive can not catch up with the transfer rate requirement of your footage.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
