Hi all, anyone experience this? Everytime I import a pretty big wmv file 1hr+ almost dvd quality (640x480) then premiere pro 3 will become unresponsive. I have waited for few min and need to clos it down. Any work around to this?
It may well be that Premiere Pro isn't designed to work with the WMV format. It's aimed at semi to top-end pro users and they work with DV, HDV and uncompressed.
Try Windows Movie Maker instead.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Well I am not editing it, just want try to convert it to mpeg2 dvd. I have tried several wmv that is OK with tmpgenc and all give same problem under premiere pro. Will the premiere 'lite' version will be better with wmv? I am suprise the apps with premiere pro caliber don't like wmv!
Also anyone get avi synth to work with premiere? I tried the plug in and it crash. -
In that case, you need to find a tool that will accept WMV as an input and that will also convert to MPEG2 for DVD. Maybe FAVC or DVD Flick.Originally Posted by hanugro
Highly unlikely. "Lite" versions of applications tend to be the same in essence, but with the less fancy / professional capabilities.Originally Posted by hanugro
Any apps with true "pro" calibre (not just in their name) are designed for pros, funnily enough. And pros don't work with crappy formats like WMV - hence why apps like Premiere Pro tend not to work with formats like WMV.Originally Posted by hanugroThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Found the answer here. http://kb.adobe.com/selfservice/viewContent.do?externalId=332447
But I wonder how long does it take. I always close it after 2-3mins and I have decent dual core procs. Gonna try to wait for longer time next time. I works with many format and I thought 'pro' means that
. Thanks anyway.
Importing MPEG-2 videos on Premiere Pro on OS X Lion
By Atoon in forum MacReplies: 1Last Post: 1st Feb 2012, 04:08 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
Importing AC3 into Premiere Pro ?
By Zetti in forum EditingReplies: 14Last Post: 23rd Jan 2009, 01:45 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 15:18
