Can anyone help me??
I am trying to burn on a Verbatim DVD-R DL using Nero and a Pioneer DVR 110D burner but Nero will not allow me too.
If anyone can help it would be greatly appreciated.
	DVD-R DL discs suck. The best advice I can give, and I love Verbatim by the way, is to NEVER again buy DVD-R DL discs and use DVD+R DL if you possibly can. The -R DL discs cost more than the +R DL discs and even worse, what the manufacturers had to do to get the layer break to work on -R DL media is kind of kludgy.
 You MUST without exception set the layer break manually on DVD-R DL media. DVD+R DL media allows the layer break to be set at various places, but -R DL media requires the break to be set at a specific location. I am not sure that any version of Nero can set the layer break correctly for DVD-R DL media. I am working from memory here, but what you have to do is see how many sectors are on your DVD and I think you have to set it for the midway point. 2092896 will probably work on your discs as the value to use, but I can't guarantee it. If your discs are made any different from this (it is theoretically possible to do so), this layer break setting will fail. The current ImgBurn has a Write setting for "Use Layer Jump Recording (-R DL)" that might be helpful to turn on. This illustrates why -R DL media sucks and why you should avoid it. You have to do none of this crap with DVD+R DL media, where ImgBurn can simply calculate the optimal layer break to use for you.
  Best IDE Burner for burning Dual Layer or Single Layer Discs for DuplicatorBy Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16
  Dual Layer Burning IssuesBy bboy2448 in forum Newbie / General discussionsReplies: 13Last Post: 28th Sep 2010, 21:12
  Dual-Layer burning of DVD using nero?By mr_jbloggs in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 08:26
  Dual layer disc error (2nd layer not burning properly - AVCHD)By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
  Dual Layer Burning HelpBy MMP in forum Authoring (DVD)Replies: 16Last Post: 4th Aug 2008, 15:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
