Help me !! Someone knows how unlock a Curtis DVD1057 !?!? I already tryed many other Curtis DVDs ways, but it is doesn't work !!!
	Unlock how? Make it "region free"?
 /Mats
	Yes ! Sorry !! How to operate this equipment in Region Free !?!?! I already tryed many Curtis codes, but they didn't work !!
	Well, as the sticky in this forum says, not all (less and less, it seems) players can be made region free, if they aren't so to begin with.
 OTOH, you just have to do a backup (always a good idea anyway) of the region protected disk to make the disk region free.
 Then comes the issue with different TV systems (NTSC vs PAL)...
 /Mats
	Hey ! I didn't understand !!! This is a regular DVD Player, brand Curtis !!! THe chipset is suppose to be similar in all of them, what in my "mind" there are some options to unlock for region free !! I don't know which backup are you talking about, because there is no software to protect.
 Don't you think some codes, such as 9735, 7912, 1.1.1.1, or something like this, with the tray openned, it soppose to work ?
 Thanks for your help. It is always an additional knowledge.
	The backup I'm referring to, is a backup of the DVD that has the wrong region.
 If you have a Region 2 DVD and a Region 1 player, back up the Region 2 DVD to DVD-R, and you'll have a region free version of your Region 2 DVD.
 And no, I don't think "some codes" is supposed to work. Manufacturers change firmware versions (the firmware, not chipset, is what determines if a player is/can be made region free or not) and remove/change these kind of "back doors" all the time. Hack codes may or may not work. If you really need a region free player - Buy one that is region free out of the box.
 /Mats
	Thanks for the tips !!! I really didn't know many things that you wrote !!! I will try to change it for a Coby which I have the codes to change the firmware to free region.
 Regards
  Curtis dvd 1098bBy WapGiovan in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Mar 2012, 07:20
  Curtis DVD1041 region hackBy sarahlt33 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Dec 2011, 08:56
  Curtis DVD 1102 new firmwareBy oldfart13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Nov 2010, 21:02
  Curtis DVD1098B Hack HelpBy stabwest88 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 22nd Apr 2010, 15:00
  Curtis DVD2100 Recorder SetupBy headusher in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Dec 2007, 11:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
