Hey guys,
I read on this man's website who copied from this website that there are ways to program your NTSC DVD Recorders to play PAL DVDs? Is this really possible?
Here is the link:
http://www.askdavetaylor.com/how_can_i_watch_pal_dvds_on_a_regular_ntsc_tv.html
I have a Toshiba DVD Recorder RDXS34 and a Panasonic DVD Recorder DMR-ES35V.
Or is there a DVD player you recommend that can play these DVDs and I can convert them through my recorders?
DJL
A player can at times be made multi region with the remote. But I've yet to see a player that can be made multi TV system, if it's not from the start.
The region protection code is a made up obstacle - different TV systems is a real technological issue.
/Mats -
You need to get a player that does TWO things. It needs to be able to play DVD's from all "regions"....and it needs to be able to convert between PAL and NTSC "on the fly".
You won't be able to record the output to a DVD Recorder however. Copy protections built in to the DVD will prevent it.
Oppo brand players are very popular in the US for doing such things. There are others but you will need to research what is available locally (or online) to you to determine if indeed they can do BOTH things listed above. A simple region hack is not a guarantee that you will be able to view the DVD. -
LG and Philips are pretty popular with the all-region hacks. Both manufacturers generally make DVD players/recorders that can convert PAL to NTSC.
Don't forget to peruse https://www.videohelp.com/dvdhacks -
I just want to second hech54's post. While it certainly is not so stated in the original post, some posters are clever and hide their true intentions. If the original poster intends to record the output of PAL DVDs played on one DVD player into his DVD recorder, this won't work because of Macrovision.
OK. Let me see if I can explain.
I had a Lite ON DVD Recorder which had no region code. I was able to plug it into the Toshiba DVD recorder and record the material from the PAL DVD to the Toshiba DVD without a problem. Is this possible with any DVD Recorder that is a no region code player? I guess that's what I"m looking for and hope that clarifies it better.
DJL -
After you did your dub, was the DVD recorded on the Toshiba, PAL or NTSC system? That is could you play it on a standard NTSC DVD player hooked up to a NTSC only TV, or was it PAL, playable only on a PAL or multi system TV?
Yes, I was able to play it on a NTSC DVD player.After you did your dub, was the DVD recorded on the Toshiba, PAL or NTSC system? That is could you play it on a standard NTSC DVD player hooked up to a NTSC only TV, or was it PAL, playable only on a PAL or multi system TV?
Does Philips BDP3406/F7 play PAL DVDs on NTSC TV?
By whachano in forum DVD & Blu-ray PlayersReplies: 22Last Post: 3rd Aug 2013, 00:37 -
Converting PAL DVDs to NTSC For HDTV
By Startropic1 in forum DVD RippingReplies: 8Last Post: 9th Jun 2010, 10:34 -
Help finding DVD player+recorder that can play NTSC DVDs on PAL TVs
By kumi in forum DVD & Blu-ray PlayersReplies: 13Last Post: 30th Nov 2009, 22:33 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
Converting Region 4 (PAL?) dvds to NTSC (USA)???
By denise8593 in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2007, 08:09
