Mac OSX 10.5.1.
When i try to mux an avi (xvid) + another audio track (tool avi+1) very often don't work. If work, the file has some problem. When i use the muxed file on a standalone player it is impossible to change the audio track or use fast forward. The player freeze.
Same problem using d-vision. Only handbrake produce very perfect muxed file.
So I try to use VirtualDubMod to correct the wrong muxed file. VirtualDubMod, when i load the muxed file, say to me that there is a problem about the second (muxed) track. Exactly it say that the header of the second track tell that the the file is encoded in wrong way VBR instead of CBR and VirtualDub ask the permission to rewrite header. I say ok and then the muxed avi work fine in standalone player and in pc.
Is it possible solve this problem.
Thank for replay, and sorry for my english.
I solved using binary ffmpeg and a command line string:
ffmpeg -i input.avi -i audiotoadd.mp3 -ab 128 -acodec mp3 -vcodec copy -f avi newmuxedfile.avi -acodec copy -ab 128 -newaudio
In this way work either on pc and standalone player. !!!
Solved: Subtitles wrong color after converting from DVD to avi sub/idx
By jimdagys in forum SubtitleReplies: 4Last Post: 2nd Jun 2011, 03:38 -
Easiest way to convert and mux audio to raw avi
By mukluk909 in forum AudioReplies: 4Last Post: 30th Nov 2010, 04:08 -
Mux many audio & video files to avi
By Urban20 in forum EditingReplies: 3Last Post: 29th Apr 2010, 04:35 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
