Normally, I load my video file into nero 7 and it is able to encode and burn it as a dvd-video which works perfectly. However, nero 7 can't load a .mkv file. I tried Super (C) and I don't think it worked at all, I tried Prism Video Converter it had very good quality and audio but later on in the video file, there was an audio video delay that lasted throughout the entire video. So, can I get a suggestion for one video conversion program that I can always use to convert any video format to any other video format that is easy to use, and does not have an audio/video delay?
You will quickly learn that there isn't a special/easy/All-in-One/fast tool that works with ALL files. You will overtime end up with a "master" tool for each filetype which will usually work with 90% of the files you deal with. And then you will have numerous other tools for all of the problem files. To make matters worse (in this case) you are dealing with mkv files which are fairly new, and like avi files, can be encoded numerous ways which pretty much screw up the "single tool" idea.
This issue has also been covered numerous times recently and a quick search will provide you numerous posts and ideas, including this one: https://forum.videohelp.com/topic342909.htmlGoogle is your Friend
Problems after converting mkv to blu-ray format
By BigGreenie in forum Video ConversionReplies: 17Last Post: 7th Jan 2012, 06:27 -
converting audio format in .MKV
By Sliver in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 07:09 -
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 06:15 -
need help converting MKV to DVD format
By ezramoro in forum Newbie / General discussionsReplies: 6Last Post: 31st Jan 2010, 23:04 -
Converting MKV file to DVD burnable format
By ryoden in forum Video ConversionReplies: 6Last Post: 29th Jul 2008, 13:54
