Hello all!
I had a lot of troubles with playing DVD's on my PC (since I don't use Power DVD or any other programs like that) and I just can't seem to find the right codec the Elecard codec doesn't support deinterlacing and those lines are all across my screen. With DScaler MPEG Filters my program (BSPlayer) just freezes... I was wondering what codec do you use to play DVD's normaly? I really don't like Power DVD thats why I don't want to install it...
Please assist...
I'm pretty happy with KMPlayer for DVDs and Zoom Player for just mpeg2 files. Not sure if either will work under Linux though, but they will work with your XP.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
I'd recommend trying VLC also. To play back a DVD with most other players, you need a MPEG-2 codec installed.
But a DVD also has a structure, chapters, menus, subs, alternate audio. For that you also need a player that can recognize all that. VLC is still a good choice, but there are also other freeware players that can display a DVD properly. https://www.videohelp.com/tools/sections/video-players But with Linux, your choices may be limited.
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 16:39 -
Mpeg Problems
By marbletravis in forum EditingReplies: 4Last Post: 23rd Jun 2008, 12:24 -
Mpeg Layer 3 problems
By ada1984 in forum EditingReplies: 7Last Post: 8th Nov 2007, 21:30 -
MPEG 2 problems
By specwarrior09 in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2007, 12:16 -
Problems converting HD Mpeg
By fearmyrage in forum Video ConversionReplies: 3Last Post: 7th Jun 2007, 22:46
