Hello all,
I seem to be having some problems getting the AC3 5.1 audio in sync with my MPEG-2 video during the DVD authoring process.
I downloaded part of a television series in .mkv format that I want to put on DVD. I managed to extract the AC3 audio and encode the video to MPEG-2 format, however, there seems to be a a/v sync problem.
I've been using DVD-lab Pro for DVD authoring, it does offer an audio delay option, but if you don't know exactly what that delay is, you're SOL. No real-time audio/video (I think it's time to find better DVD authoring software, any suggestions?)
Anyway, I would like to know if and how I could fix this. I would rather not have to re-encode the AC3 audio (it's about 5 seconds out of sync), but if I do, how do I trim the audio? Do I have to separate the channels? If so, how do I demux the AC3 to separate streams?
Any suggestions/advice is greatly appreciated,
Thanx for now,
Cheers,
ziggy1971 8)
Results 1 to 13 of 13
Hi AlanHK,
Thanx for the link, I'll give it a try and see if it can fix the problem.
Cheers,
ziggy1971 8) -
Load the elementary streams (video and audio) into Media Player Classic and use the + and - keys on the number pad to adjust the delay until you sort out what it is. You can then use DelayCut or DLP to adjust for it.
Read my blog here.
Hi guns1inger,
How do you load elementary streams (video and audio) into Media Player Classic?
Cheers,
ziggy1971 8) -
Hi guns1inger,
Now why wouldn't the makers of Media Player Classic just have labelled the fields "video" & "audio" instead of "Open" and "Dub"? It would've made things so much easier and I wouldn't feel like a complete idiot for asking such a trivial question.
Oh well, thanx for the info though.
Cheers,
ziggy1971 8) -
Normally, if the files are in the same folder with the same name, MPC loads them automatically.Originally Posted by ziggy1971
Eg: if you open movie.m2v and you have movie.ac3 in the same folder, the audio will also be loaded without you having to select it. Somtimes this can be annoying, but usually it's what you want. -
Do you use Klite codec pack? I have this issue on 2 Pc's I installed this on. Tmpg dvd Author 3.x, goldwave have issues in keeping Ac3 in sync when I convert AVI to Mpeg 2. When my PC's play these files it works perfect. Only when I convert it do I have these issues...
[DVD Lab Pro] Does not accept audio delays
By dom61 in forum Authoring (DVD)Replies: 3Last Post: 3rd Sep 2011, 08:35 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
TSmuxer delays
By vassock in forum Authoring (Blu-ray)Replies: 0Last Post: 15th Jul 2009, 23:57 -
Regional DVD has Audio delays in each .VOB files
By maass in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2009, 08:36 -
streaming delays
By golfersb in forum Newbie / General discussionsReplies: 1Last Post: 27th May 2008, 15:22
