Yesterday I got OPPO-980H. Amazing quality and attention to details, even packaging is top notch. Picture and sound are great comparing to LG LDA-831 I used before. The main reason I've replaced LG was to get rid of occasional freezing on some Russian "grey" market DVDs. LG had to be power cycled to get back on track.
The first Russian DVD I played yesterday in oppo was an aftermarket DVD with multiple movies. The movie I watched was good except it froze few times at some point then it continued to play just fine. Most likely it's the DVD defect. However, I thought I'd ask, if there is something I can do to minimize the freezing.
Thx.
Could be the actual disc is dodgy?,,do a copy using a known good blank, use a lens cleaner on your burners first.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I have been to Ukraine and I have one of these "grey market" DVDs, so I know what you are talking about. I'm sure it's a disc defect and I don't think there is anything you can do.
Originally Posted by mikhail_f
It's probably poorly authored and burned.
either that or Putin has sabatoged the discs -
I'd agree with Movie geek, unless it is a very rare item.
You can extract the material and then re author/encode.PAL/NTSC problem solver.
Great! Thank you. The movie isn't something very important, so whenever I have time I might copy it, then burn it on a good blank DVD to proof it's the DVD disk defect.
What brand of dvds and what type of dvd do u use???
By jones24 in forum Authoring (DVD)Replies: 29Last Post: 7th Nov 2008, 00:21 -
Considering buying Oppo DV-980H or ??? Opinions wanted.
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 20th Aug 2008, 14:52 -
New OPPO DV-980H Firmware Available
By Grain in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Apr 2008, 17:59 -
OPPO DV-970HD HDCP Hack // OPPO 983
By Grain in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jan 2008, 01:29 -
OPPO DV-980H Frezzes If Stopped For TOO Long ??
By ofield in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Sep 2007, 07:09
