Hey guys.
I have a Spanish movie in VIDEO_TS format. I have the English subs for it in SRT format. I want to author a DVD with selectable subtitles. What is the easiest way to do this? Can it be done without reencoding? I hope so!
Thanks.
Results 1 to 9 of 9
Without reencoding: Yes.
Without reauthoring: No.
Basically, get the movie in mpg format, reauthor with an authoring app that supports subtitles (and .srt import).
/Mats -
1/ Extract the main feature as single file VOB
2/ Rename the .vob to .mpg
3/ Use ffmpegX's Author tool to re-author with selectable subs
4/ Hope that the timing on the subs syncs...
That worked just like you said, Case. Thanks again for the prompt and spot-on help. I owe you a six-pack.
Case, I tried this method to add subtitles, but saw the error message "The variable _videoinfo is not defined. (-2753)", and no authoring took place.
I had started with an avi file, which Toast 8 converted into an image for me. I mounted the image, used MTR in the way you described and changed the vob into a mpg file. However, the result was as shown above.
I had earlier tried to add the same .srt file to the avi I started with, using Filters/Load Subs with "VOB subtitles" checked, but when dragging it into ffmpegX, saw "Unrecognizable" in the "From" window, and the encoding process took only a couple of seconds, with no visible output file.
I wonder if the original avi file had some undefined variable that ffmpegX is looking for, and which is not present in either the avi or mpg form.
Do you have any suggestions? -
Try Jubler first with the subtitles and movie. You can change the font size, color, timing etc... It's free and when you know it works and lined up you can save to many different formats that can be recognized if the original is not being recognized by your authoring program.
I don't think I've seen that one before.Originally Posted by bluecrab347
Odd contrast between the two. Try to find out which codecs are used in the AVI, and go from there.Originally Posted by bluecrab347
Maybe QuickTime (Cmd-I) or VLC (Cmd-I) can tell more about the codecs?
Maybe the AVI (-header) is 'broken' and has to be fixed first? -
Dear Case!
I hope you can still help me. I did everythingh that you wrote (used terminal for joinign the vob file into one single file). And after that I "author" the mpg with the new subs. But now i have a little problem. The new (english) subs are working but they shown over the original subtitles in VLC. What can i do?
Please reply me quick if possible.
Thanks -
I suppose that could happen if the original subtitles are hardcoded; i.e. part of the video. I think that's the only way for VLC to show both at the same time.
Programs like iSubtitle and Submerge will use a somewhat dark band between the video and the new sub to make 'em stick out more. Not sure how these deal with VOB files, though.
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 07:30 -
add .srt to BD
By Benjy in forum SubtitleReplies: 1Last Post: 14th Aug 2010, 19:16 -
ffmpegx, video_ts to .avi with mencoder, won't create .srt subtitles
By patrapao in forum MacReplies: 4Last Post: 14th May 2009, 20:36 -
How To add srt onto VOB/MKV?
By LeorD in forum SubtitleReplies: 0Last Post: 1st Jan 2009, 16:17 -
add/burn srt sub into avi
By volam in forum SubtitleReplies: 2Last Post: 24th Aug 2008, 05:48
