				Results 1 to 11 of 11
	It would make more sense to show the example frame at the original resolution. If it is interlacing, it will get completely mangled by the resize and might look like this. In any case it will be difficult to help without an example video clip, rather than just one frame.
	It looks like improperly resized interalced video. You should deinterlace or inverse telecine before resizing.
	I'm sorry but my Internet connection is too slow to let me upload video clips.Originally Posted by ajk
 I think you are referring to the original video (before the resizing) which, unfortunately, I don't have. So, as I understand, there's no way to fix it, right?Originally Posted by jagabo
 Here's a full size frame
	Yes, if the field structure is already messed up by resizing you won't be able to fix it.Originally Posted by Lure
 I'm not sure what's going on in that image but it doesn't look like interlace artifacting.Originally Posted by Lure
	That's almost certainly due to resizing an interlaced (or telecined with 3-2 pulldown) source without deinterlacing first.
 It will only effect movement (i.e. where something changes between one field and the next), because if there is no change between two fields then there are no differences to corrupt.
 I don't know of a fix. Whenever this problem crops up on the doom9 forums, the answer has always been that there's no fix. You'd think it would be possible implement something to improve it somewhat, but no one has yet!
 Cheers,
 David.
	With interlaced video each frame contains half of two separate pictures, called fields. One field is in all the even numbered scanlines, one is in all the odd numbered scanlines. If a frame is resized on the vertical axis parts of one field get "contaminated" with parts of the other field. Once this has happened it's no longer possible to separate the two fields for proper display.
	Probably your best "fix", if available, is to get a retail DVD. If you've downloaded the video, you are at the mercy of the (in)experience of the person encoding it.
 The way anime sells these days, I'm sure that what you have is available.
  Removing jagged interlacing artifacts from a progressive file?By tfolder in forum RestorationReplies: 13Last Post: 17th Mar 2011, 05:19
  Interlacing artifacts appear from interlaced clips?? Sony vegas + tmpgBy mazinz in forum EditingReplies: 10Last Post: 28th Sep 2008, 20:51
  Good Video Explaining Interlacing and De-InterlacingBy Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50
  Interlacing artifacts on poor VHS conversionBy binister in forum Video ConversionReplies: 6Last Post: 2nd Jul 2008, 20:05
  Interlacing artifacts out of control on home video VHS to DVDBy bobbyt in forum Video ConversionReplies: 3Last Post: 8th Jul 2007, 16:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
