Results 1 to 13 of 13
  1. Hi
    Is anybody out there that can help me to solve a mystery of how to convert DVD menu and extra footage from PAL to NTSC? I have a whole bunch of disk in pal system(that is not copyright protected) yet I need to covert into NTSC system. Converting video files is no problem, but the menu is untouchable. I simply can not make it same disk there is in pal and all the menus and extra, to NTSC. Please if anybody knows how to convert that stupid menu from disk , so that I can have the same disk, there is in pal system in NTSC system.
    Which software will do that?
    Thank you very much
    Daniel Ocko[/b]
    Apr 2004
    Miskatonic U
    There is no software to do it. The only way to do it is to pull it all apart, convert each part, then re-assemble it. In short, it can be done, bit is difficult and time consuming. Those that have done it (and if you search you will find posts on how to do it) usually only attempt it once or twice, then go and purchase a player capable of playing PAL discs so they don't have to do it again.
    It is far simpler to re-author with your own menu.
    Read my blog here.
    USA
    This one is NTSC to PAL, but it might give you an idea what would be involved. https://forum.videohelp.com/topic342775.html
    And this isn't Latest News. Moving you. Please post in the proper forum.
    And welcome to our forums.
  4. try Numenu4u I did that to convert DVD menu from PAL to NTSC, then, convert main movie, extra...ect...and reinsert menu back ...try to see if it works for you..
    Sep 2009
    That is exactly what i've been trying to do and everytime i try i just get a PAL menu not a NTSC converted menu. do
    you know how you did that using Numenu4u ?
    thanks
  6. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    It will convert in either direction. You'll need Scenarist to work with Numenu4u. There's also a VIP version for working with Muxman instead, but the program is no longer supported (VIP options were activated by serial #, via donation).
    Sep 2009
    I have Scenarist installed and CCE . My question is how do you get it to do the conversion. I put a PAL DVD in
    the drive and using the wizzard and selecting the option to do a conversion at the last screen in the wizard i
    rip the menu to my HDD but my PAL menu comes out as PAL . It doens't do any conversion. I set the paths
    to my CCE and Scenarist and softencode for the audio. I've read were others were having this same issue
    on Doom9 and then they must have received a PM as they just got it working without anyone openly stating
    how to do it. Am i supposed to be getting a PAL menu from a PAL DVD and then do the conversion using
    another method ?
    The program seems so straight forward but it just isn't converting to NTSC . The menu is a still menu.
  8. Maybe this will help, and maybe not:
    http://originaltrilogy.com/forum/topic.cfm/Doctor-Ms-berGuide-for-Full-PAL-to-NTSC-DVD...opicPost343735
    The NuMenu4U menu section is in Part 6, not quite halfway down. I could never get NuMenu4U to work at all, the couple of times I tried it a long time ago. This is about the best guide I've seen for this, except for the fact that it relies on some expensive and some dead software. Maybe you've already discovered this guide.
    Sep 2009
    NuMenu4u freezes up on me when in the Scenarist stages, donations are no longer being accepted from
    what i've been told. I've put quite some time into this and finally....FINALLY got it all working. The multiple
    menu system on 16x9 DVD's along with the subpictures was a major set back. I managed to find another
    method that works and i feel it's flawless. I've tried this on 2 other 16x9 titles once i got it working and
    so far no issues. All these menus were still menus but the motion menus would only be an extra step.
    I have almost finished a tutorial ( text,screen shots and videos of each step ) but i've been advised
    against posting it here. Check out the complete PAL > NTSC menu conversion i've managed to
    complete ( only took 2 weeks of surfing ). I'd be ashamed to admit the number of hours i've put into
    doing this but it's good exercise for the mind, beats being a couch potato.
    Phe0nix
  10. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Doom9 has a guide.
    Sep 2009
    Yes, i've seen it. I have been searching for information for weeks and have come across that guide.
    Have you tried that guide Alex, i don't think you have other wise i doubt you would have mentined
    it. This is a very involved process and will take up alot of your free time so it requires alot of devotion.
    If you open the program it clearly says that at the top of the window
    bobby2002 had success using NuMenu4u and since it was freezing up on me , i was looking for a response from
    him. His post was from 2 years ago but i was worth a shot. I've found a different method so i don't need
    the program anymore.
    Aug 2004
    I've used numenu4u a number of times before with muxman when converting menus from PAL to NTSC, and maybe there were only a handful that have had a problem. So I can confirm that it does work most of the time. For the ones I did have a problem I usually just did it manually. And it is possible with free tools although of course it's a more time consuming process than using numenu4u. But here are a couple links from awhile ago that pretty much summarizes the method I used:
    https://forum.videohelp.com/topic311436.html#1601718
    and on converting the subpics:
    https://forum.videohelp.com/topic362241.html#1926061
    Sep 2009
    Thank You Pinstripe23, through my searches i've run across many of your posts on the subject your input
    is much appreciated .
    Phe0nix
