hey all i use TMPEGEnc to encode DVD to SVCd and i didn't use Source Frame Range and now i got a 1.34GB file i want to divide it into 2 so i can make it 2 cds how do i do thata nd what program?
Results 1 to 10 of 10
argh
that won't help me bbmepg quits onme when ever i try following the tut and TMPEGenc has this glitch noise at the end of the cut which pisses me off so what do i do?
You should be a little more specific. "bbmepg quits onme" , what does it mean? Did you try any other tool?
yes i tryed TMPEGEnc and it leaves a noise at the end of the cut which pisses me off like a glicth noise and BBMPEG quits when i click OPEN PS
I ran into the same problem with bbMpeg, and after searching the web, found a solution. It's apparently only a problem with Windows XP. The workaround is to click "Load" on the first screen (before clicking "Start Encoding".) Cancel out of the load dialog box, and proceed normally.
I think I had the same problem as well... until yesterday, BBMPEG did not do what it normally does. When it tried to split the movie file and and also add the .mp2 file, it stoped right after it finished the first CD. The movie file length is 2 Cds. Whether I set the CD size to be 720 (74mins) or 780 (80mins), it just stopped right after it finished the firsth CD and could not go on to finish the rest.
My OS is Win2K so I dont know the solution "click on Load first" would do the trick or not but will try later today. -
antonio,
i tried to follow your link but it says the url is not available. i to have had similiar problems with TMPenc. only, when i try to split an mpeg i receive an error that looks something like this "error at address 7985655423e at address 7985655423e" then the program closes. anyone ever seen this error ?
i have been looking for another free splitting tool, anyone know of any descent free ones ??? -
i downloaded dvtools last night and it worked great. it is lacking instructions and took me a while to figure out how to use it, but once i figured it out, there was no problems with it at all.
pretty decent program, especially for free !!
Using HJ Split
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 00:59 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
How do I split a SVCD
By VoXiSo in forum EditingReplies: 1Last Post: 4th Feb 2008, 15:14 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
