Well I've been using ubuntu for a few weeks now and am really liking it. The only problem is that after a reboot from windows to linux this morning Ubuntu no longer sees my ntfs drives. What the heck happened? Anyone have any ideas or suggestions on how to get them back?
The funny thing is these drives are recognized just fine in windows. Any thing I can do short of a fresh install (don't really want to go that route as I finally have things the way I want them).
Edit-- Okay I'm not sure what the problem was but it's working okay now.
Final Edit--- Jan 18, 2008 I still don't know what caused the problem but I now know what fixed it (because it happened again recently). To fix the missing drive problem I just had to boot into windows then reboot into ubuntu. That fixed the problem.
Donadagohvi (Cherokee for "Until we meet again")
Okay some more info the drives are there they just arent mounted any more.
Code:Disk /dev/hda: 40.0 GB, 40020664320 bytes 255 heads, 63 sectors/track, 4865 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x00710070 Device Boot Start End Blocks Id System /dev/hda1 * 1 4865 39078081 7 HPFS/NTFS Disk /dev/hdb: 60.0 GB, 60022480896 bytes 255 heads, 63 sectors/track, 7297 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x9d1e9cf6 Device Boot Start End Blocks Id System /dev/hdb1 1 5678 45608503+ 7 HPFS/NTFS /dev/hdb2 * 5679 7223 12410212+ 83 Linux /dev/hdb3 7224 7297 594405 5 Extended /dev/hdb5 7224 7297 594373+ 82 Linux swap / Solaris Disk /dev/hdc: 41.1 GB, 41110142976 bytes 255 heads, 63 sectors/track, 4998 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x218e3293 Device Boot Start End Blocks Id System /dev/hdc1 * 1 4998 40146403+ 7 HPFS/NTFS
Ubuntu 10.10 draining my battery?
By Poppa_Meth in forum ComputerReplies: 21Last Post: 5th May 2011, 06:48 -
Renaming Directories - XP Crashed - NTFS Drives
By wormhole1969 in forum ComputerReplies: 8Last Post: 18th Nov 2008, 18:15 -
VLC 0.9.2 deb for ubuntu
By freebird73717 in forum LinuxReplies: 17Last Post: 29th Sep 2008, 10:31 -
Ubuntu 7.10 released
By Baldrick in forum ComputerReplies: 10Last Post: 26th Oct 2007, 11:41 -
Dual Boot Ubuntu Err 21 on PC with XPPro on RAID0 Drive and Ubuntu on eSATA
By videocheez in forum LinuxReplies: 32Last Post: 11th Jun 2007, 01:51
