Hello,
I recently bought the SL-6502 PSX2 Gamepad Converter
and installed the latest WinXP drivers (sl-6502_03_07)
from the drivers section speed-link home site (Same as
the ones in the enclosed mini-disc)
http://www.gc-plus.de/bin/sl-6507/sl-6502_03_07.zip
http://www.speed-link.com/
http://images.speed-link.de/prodpics.../sl-6502_1.jpg
The converter works perfectly with my standard SONY
PS2 gamepad, but I have a few queries concerning the
button setup and properties.
If I run “Game Controllers” from the WinXP control
panel, the default button state designations are as
follow (By pressing / testing the buttons on the
gamepad):
Button 1: Triangle
Button 2: Circle
Button 3: X
Button 4: Square
Button 5: L2
Button 6: R2
Button 7: L1
Button 8: R1
Button 9: Select
Button 10: Start
Button 11: Left Analog Stick
Button 12: Right Analog Stick
What I would like to do is change the button
designation from the WinXP “Game Controllers menu” and
permanently assign them to:
Button 1: Square
Button 2: X
Button 3: Circle
Button 4: Triangle
Button 5: L1
Button 6: R1
Button 7: L2
Button 8: R2
Button 9: Select
Button 10: Start
The reason I want to do this is because a lot of WinXP
games do not allow you to remap the gamepad keys to
suit my gaming needs and the default button
designations from the SL-6502 drivers are not ideal
for me.
My System:
WinXP PRO SP-2 English
Intel Core2 Duo @ 2.4GHZ 4MB Cache
ASUS P5B-E M/B 8-USB ports (The SL-6502 PSX2 Gamepad
Converter is connected to the front USB port)
2GB DDR-2 PC6400 800MHZ
Sound Blaster Live 5.1! (PCI)
Nvidia GeForce 7950 512MB PCI-X
SeaGate 500GB SATA-II 7200RPM
SeaGate 500GB ATA 7200RPM
ASUS 16X DVD-ROM
Plextor 18X DVD-Recorder PX-810SA
So, is there any way to change the default button
designations from the SL-6502 WinXP drivers?
Thanks in advance.
Results 1 to 1 of 1
First Unread button
By olyteddy in forum FeedbackReplies: 3Last Post: 21st Mar 2010, 16:12 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
no controll button
By moshe1980 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2009, 05:27 -
Easier way of using a gamepad rather than manually configuring every button
By ryangarfield in forum ComputerReplies: 3Last Post: 24th Jun 2007, 10:29 -
Autofit button not working
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th May 2007, 16:23
