Hello Guys
I just got a lg blu-ray rw for x-mas( happy x-mas to you )i want to bak up blu-ray dvds and view them via my xbox also an mvix 760hd but mainly the xbox,so what softeare do i use,i dont know much sbout formats in hd.
At the moment im ripping all my dvds with dvd decrypter to single 4,5 and 6gb files and then using tversity to stream to my xbox,my mvix reads mpeg2 so the files are compatible,what i like about this is there is no converting is involved so all i have to do is rip and i am keeping the best quailty possible in video and sound and this is what i want,i hope you can help me.
thanks alot.
Eamonn![]()
Yes I'm trying to do that as well.
Ultimately I want to rip my Blu Rays and encode them into high quality AVI's to be played on my various portables.
Since BD-Roms can be had for under 200 now I think I might try it.
I know that you can use AnyDVD-HD to open them up willy nilly... But I don't know how they get ripped. And I don't know what software takes what gets ripped and turn it into a VOB or other video file that I can use to make an AVI/MP4 etc.
All mysteries to me....
And I don't know if there current generation BD-Roms are going to handle profile 1.1 discs when those start coming out. I'd think it would work but that purely a guess (as the only thing profile 1.1 adds in web content and PiP support).
I'd figure current gen drives could rip them just fine.
Not to hijack your thread or anything but getting these questions answered would be peachy keen, lol.N/A -
Whenever I import either my MPEg TS or M2TS into DGindex to try and rip the audio whatever PGC I choose it just says 'No Video Header Sequence Found'. I also Tried to open in Virtual dub but still no dice.I've used TSremux and select various combinations even one that clearly says AVC video Stream.Still the same thing.
Just a note, you don't need TVersity to stream to XBOX360. Either take the VOB files and rename to MPG or convert to divx (which saves space). Both of these can be played directly from XBOX360 dashboard. You will need Windows Media Player v11 configured for sharing, which is documented at xbox.com/pcsetup.
is it difficult to copy blu-ray movies as opposed to ripping or doing a disc to disc copy of standard def dvds??
Blu Ray as back up issues
By dmid94 in forum Newbie / General discussionsReplies: 10Last Post: 27th Nov 2011, 09:41 -
Do i need to upgrade for blu-ray back up ?
By solo in forum Authoring (Blu-ray)Replies: 9Last Post: 7th Nov 2011, 09:44 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 12:34 -
Best way to back up my Blu-Ray Collection?
By Beast Lee in forum Blu-ray RippingReplies: 7Last Post: 17th Jun 2011, 05:42 -
How to back up blu-ray DVD?
By coody in forum Blu-ray RippingReplies: 2Last Post: 2nd Sep 2010, 10:23
