Hello...
I've gone through the forums and am still unclear concerning two basic scenarios:
First, I want to save some DVDs to my hard drive as a giant file without losing any quality. What would be the format to save it to and what would be the best utility to do it with?
Second, if I wanted to edit those saved files (just basic stuff), again without losing any quality, what program would I use?
I apologize because I suspect I've overlooked the answer somewhere here, and it involves MPEGs and TMPG software. But if someone can clarify it for me I'd really appreciate it.
Thanks!
	the only way to not lose any quality is to copy the video_ts & audio_ts folders off the dvd to the hard drive. put them in a folder with whatever you wish to name it. plan for about 4.5GB/each full dvdr. it's that easy. it will still be in dvd form. --
	Thanks aedipuss.
 Does this mean that there is no file format (like MPEG) that preserves the original quality? It seems clumsy saving all those VOB files, and I'd prefer one combined file.
 Either way, what is the best program to use for editing?
 Any help appreciated. Thanks!
	The only thing you have with the "original" quality is the DVD itself. It doesn't get any better than that, for you. The VOB files are it. Any conversion is going to alter that to some degree.
 Also look at: https://forum.videohelp.com/topic343208.html
	Well, he did ask about MPEG. As VOB files contain MPEG-2 video, he can convert to MPEG with no quality loss. Try VOB2MPEG. As for getting one large file, you can get that in VOB form by decrypting into one large VOB file. It's easy to set DVD Decrypter to do that. Or do it when using VOB2MPEG on the VOBs. As for editing, try VideoRedo, Womble MPEG Video Wizard, Cuttermaran, or MPEG2Schnitt, or maybe try searching in Tools for others, freeware or commercial.Originally Posted by kimco52
	"Well, he did ask about MPEG. As VOB files contain MPEG-2 video, "
 You are correct. He still won't get any better quality than he has now.
 I have, on occasion, changed the name of vob's from .vob to .mpg and double clicked on them and they play just fine with Windows Media Player. Double clicking on .vob does not work that way.
	Maybe not a double click (without setting an association) but every player I have (including WMP) will play VOB's without a name change. I have specifically associated NeroShowTime to open them with a double click though.I have, on occasion, changed the name of vob's from .vob to .mpg and double clicked on them and they play just fine with Windows Media Player. Double clicking on .vob does not work that way.
 As usual, manono's advice is spot on.
	Yes, I could set up an association but haven't had the need to.
 I don't see anything manono said that I would disagree with.
  Editing in Pinnacle UltimateBy Ronan Carley in forum EditingReplies: 1Last Post: 30th Jan 2012, 02:11
  Newbie questions on saving, converting, burning, etc..By osb_tensor in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 23:42
  Newbie Questions DVD to ????By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 10:19
  Questions about photo saving, etc.By Captain315 in forum Off topicReplies: 3Last Post: 11th Dec 2008, 22:55
  VHS to DVD - format, saving, and Avidemux QuestionsBy maeks84 in forum EditingReplies: 0Last Post: 18th Jan 2008, 00:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
