I have a Sanyo DWM400 DVD player. It is suddenly not responding when I turn it on. It won't open/close the tray, and once it's on, I can't turn it off either. I tried unplugging it and leaving it unplugged for a while and nothing. I opened it up and nothing looked wrong inside... I had read that some times the capacitors blow their tops in this model.
I was hoping that I could do some kind of reset on it. Anyone know how?
A typical reset is just unplugging the unit for 30+ minutes.
Sounds like your player has died. You could take it to a repair shop, but it is likely cheaper to just replace it.Google is your Friend -
By the way... I think you are right. I gave up on the unit. I am now in the market to purchase a new DVD player.
Protron DVD player PD-007 in Progressive mode How do I reset.
By joe347 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Nov 2013, 21:36 -
Sanyo VPC-CG20 HD Playback Issues - Wrong codec / player??
By Houli in forum Software PlayingReplies: 2Last Post: 2nd Aug 2011, 17:40 -
Last Firmware DVD Player SANYO 9206U
By cgoddard in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jun 2011, 23:24 -
Have a Sanyo DWM 390 dvd player that shows only black and white
By blackkat in forum DVD & Blu-ray PlayersReplies: 21Last Post: 28th Jan 2011, 20:24 -
How can I find a Sanyo DWM-370 DVD Player???
By Akabane Kurodo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2008, 10:00
