  1. Hi,
    I have a VCD compliant MPEG and the audio is about 1 second behind the video. What is the best way to get them in sync?
    TIA for any advice!
    ~dev
  2. I tried this and seem to be having a problem.
    When I do the simple de-multiplexing with TMPEncode it saves the audio and video files seprately as it should, however it is only doing half the video. That is to say, the finished files are only about the first half of the video.
    Has anyone else had this happen?
    Thanks,
    ~dev
  3. no....
    are you sure your not using the "merge and cut"..??
