I'm trying to play SVCD (MPEG2) files using Windows Media Player, but it won't recognise the file ,and cannot find a codec for it automatically. I've installed Power DVD, and that makes WMP play the files, but I'd much rather get rid of Power DVD and use a third-party decoder. Anyone know where I can get a good, free one?
Thanks.
You can try Elecard, it's shareware, and software only. http://www.elecard.com/
I have Power DVD too. It doesn't auto play SVCD's for me. You can use the file mode and browse to the mpg track.
If you keep Power DVD installed (for the mpeg2 decoding) you can use STHplayer http://dvdarea.free.fr/studio/lecteurs/sthsvcd_55.exe it supports SVCD.
Yep, I'm aware of Elecard... but was wondering if there were any free decoders available.
I had the same problem. The solution was install the demo version of WinDVD at http://www.intervideo.com/jsp/Signin.jsp?mode=download and then uninstall it. It leaves the codec that allows SVCD palyback in Windows Media Player 7.
There is more info in thread http://www.vcdhelp.com/phpBB/viewtopic.php?topic=44661&forum=5
Da Kitty
5.1 audio decoder
By robinmishra in forum AudioReplies: 4Last Post: 24th May 2011, 18:22 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47 -
what's a DVD decoder?
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2007, 17:59 -
How to install a decoder
By dynamique in forum Video ConversionReplies: 2Last Post: 24th May 2007, 04:27
