I used a camera to shoot an action shot, but now I want to cut out most of the background. Is there some FREE software that will let me zoom in on the subject and cut out everything else?
The "zooming effect" in/out would be tough to do.
If the subject is always in the center of the frame of your film, you could trim the edges, +/- resize the clip - in effect this would just be focused on the subject but no "zooming effect" -
This would require a conversion or at least a frameserve but what about a virtualdub zoom filter. It can be applied on a range of frames you specify.
http://neuron2.net/zoom.html -
Zooming is easy, although the quality will suffer as this is essentially a resize up, and resizing up always leads to softer images. You might try first upsizing with VideoEnhancer, then cropping back to get just what you want in frame. Removing everything else around the object/person requires masks, and probably spline masks, which means higher end software.
Read my blog here.
no Video in MPEG Stream Clip
By al2502 in forum EditingReplies: 13Last Post: 15th Nov 2016, 12:33 -
MPEG Stream Clip and Quicktime Alternate
By alhenderson in forum Newbie / General discussionsReplies: 21Last Post: 12th Mar 2015, 17:01 -
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 11:08 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 17:14 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 08:26
