Hi,![]()
I'm having some problems with this camcorder....
I bought 3 , to use them with a videomixer like 3 different angles, so i only need a good image from the camcorder ( because i'm not going to record internally on the SD card ) , the problem is that when i connect the camcorder to the Videomixer , from the A/V Out, the image appears, but with a zoom bar at the right and some little numbers, so is there a way to remove that bar and that numbers so the image will be clear???
Hope you understand my little problem....![]()
Note: I also tried to fix this with turning OFF the Icon Option, but the zoom bar and the numbers still appear.
Thanks.
Results 1 to 1 of 1
Aiptek Digital Camcorder, any good?
By deadrats in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 12th Dec 2008, 13:54 -
Using Aiptek HD Camcorder Lagging
By bearsbowl37 in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2008, 15:54 -
Aiptek High Definition .mov files
By theguy1991 in forum Video ConversionReplies: 0Last Post: 6th Jun 2008, 11:11 -
Anyone try the Aiptek HD cameras?
By Forum Troll in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Dec 2007, 16:39 -
Aiptek offers bargain basement HD Camcorder
By BJ_M in forum Latest Video NewsReplies: 19Last Post: 6th Aug 2007, 11:42
