Results 1 to 15 of 15
  1. HI guys...I seem to have managed to burn my vcd..the video show but there's something wrong with the audio...it won't play.there's no audio..I did like everyone told me and I extracted the audio into a wav. file from my avi. from virtual dub......then I entered TMPGEnc and for the video input I put my original avi file and for my audio input I put in my wav file..then I loaded the NTSC template and clicked "Start Encoding:....I then went to ner to burn....just to maek it a little fansy I put a menu...and when I played it it didn't work.........now my question is what do u guys do to make the audio work......??????? and could the reason for the audio not working be the fact that I added a menu with no sound...or could it be because I used nero????????plz answer these questions.....thx in advance
    If u have an answer for this question u can just post a reply here or u can
    e-mail it to me at ibadk@hotmail.com
    thx....in advance.....
  2. i have had a similar problem with tmpgenc on a few movies(all vhs) only one channell usually left was recorded i had sound when played on pc but none when i played it on dvd player is this similar to what your problem is if you get sound on pc but not on dvd player do this i split audio from movie convert audio to wave then use a programe called goldwave to simply copy left channel and paste it to right channel clean it up a bit with some filters load wave into tmpgenc encode wave to mpeg audio track youll end up with a file the exact same size as when u started then multiplex both together again and enjoy only once did i get sync probs sound was just .40 secs out of sync just noticable but easily fixed
  3. a little more help would be very much appriciated
  4. a little more help plz
  5. the audio plays on my computer but not on my dvd player
  6. you might want to try to encode it dirctly with nero (it's a bit longer but i've never had any problems doing it that way...
  7. neros encoder sucks i will send guide tonight am halfway through it.Its just taking a while as the wife is a way and i have four kids to look after but i will send it tonight for me any way as i live in oz
  8. Jeepers ibadk, this must be a hot issue with you. I do like your "help" as opposed to "bump" like most do to keep their post in the limelight. At any rate, I'll try to give some help. Now, you say it works fine on the computer, but not the standalone DVD player (I paraphrased a bit there)? When you say it plays on the computer, does this mean you are playing the original file, the MPEG conversion, or direct off the VCD? ASSUMING the VCD works on your computer but not a DVD player, try setting your audio mode of your sound system to Stereo, not Dolby Digital. For some reason, I must manually switch my A/V preamp to stereo to hear VCDs.
    This answer is based on a lot of assumptions. If you want better help, give some more details.
  9. more help plz
    Sep 2001
    Japan
    Originally Posted by ibadk
    more help plz
    without more details no help is possible. Answer the above questions from House de Kris, maybe someone can help!
  11. -Maybe your total bitrate is too high or too low
    so your dvdplayer can't handle it
    -or try to mux with bbmpeg , most player will prefer that instead of TMPG
  12. Have you installed the codec drivers ?
    I had the problem with TMPGEnc, but after installing all the codes,.. problems disapeared.
    Check the download folder here...look under codec.
    May 2001
    James Whitlow
    Try modifying the method a little: Load the AVI into VirtualDub and then just frameserve it over to TMPGEnc. If you look in the F.A.Q. section of this website, you will see well written, easy instructions on how to configure VDub to frameserve to TMPGEnc.
  14. well....here are the details.......My dvd player is a toshiba 2050 and it is hocked directly to my tv with the in and out leads........I encode the audio and video on tmpgenc with the ntsc template..I don't change anything..by the way the audio is set up at stereo.....there is an option to set it at dual stereo....should I consider using that???????
    there u go....those r the details
